Ford. The oil changes are much easier
I had the 7.3L Godzilla and I wasn't impressed. I'm at around 5200 ft above sea level and tow the Ike twice a year. I got tired of the motor screaming rpms and shifting all the time. The downhill was awful too.i would lean towards a gasser unless you’re towing non stop. the 7.3L ford is an incredible driving experience. i’m partial to the 6.6L gasser from GM however.
twice a year is a pretty good trade off for the upfront and maintenance/up keep costs. there is absolutely zero reason to daily drive a 3/4 or 1 ton diesel pickup if you aren’t working it. asking for emission issues.I had the 7.3L Godzilla and I wasn't impressed. I'm at around 5200 ft above sea level and tow the Ike twice a year. I got tired of the motor screaming rpms and shifting all the time. The downhill was awful too.
I'd like to know how old that F350 was as that may shed light on that story unless he test drove two new ones.A buddy of mine bought an F450 he says it’s a better turning ratio than the F350 and a much smoother ride and it was only a few dollars more if that’s true. Plus, it’s the same size as the F350.
The F450 has the wide track front axle, thus the tighter turning radius. Handy if you have a large 5th wheelA buddy of mine bought an F450 he says it’s a better turning ratio than the F350 and a much smoother ride and it was only a few dollars more if that’s true. Plus, it’s the same size as the F350.
I daily my 2500 6.7 and have had zero emissions related issues. I don’t even tow (yet) and drive around 16k+ miles per year. My average regen is about 650-900+ miles between regens, usually.twice a year is a pretty good trade off for the upfront and maintenance/up keep costs. there is absolutely zero reason to daily drive a 3/4 or 1 ton diesel pickup if you aren’t working it. asking for emission issues.
The DEF system on my ram is remarkably simple and robust if you don't put the wrong nozzle in the wrong tank. On my truck the SCR and DPF are separate and can be serviced/replaced individually if needed, unlike Ford's giant telephone pole log unit.Which one has less DEF issues?
Yet. DPF’s need heat to clean themselves. there will be permanent build up after a while.I daily my 2500 6.7 and have had zero emissions related issues. I don’t even tow (yet) and drive around 16k+ miles per year. My average regen is about 650-900+ miles between regens, usually.
I hear this frequently. How much additional maintenance does the diesel really require? Is the pesky 15k fuel filter interval and 100k CCV filter interval really a burden? Oh, and two coolant systems to drain and fill every 5-10 years vs one (ford and gm). Drain a water separator every few oil changes? Fill a DEF tank at the pump every 3k-5k miles?Yea it would have done the job, but I was getting a bigger camper that the F350/7.3L wouldn't handle. MUCH less maintenace than the diesel though.
Because the curb weight (depending on equipment) can be lower and the class 3 14k gvwr limit is same for 350 DRW as 450. Obviously the 450 is derated on gvwr. Different people have a different level of care when it comes to ratings and a different understanding of the class 3 truck 14k cap.And the F350 has a higher payload than the F450...![]()
There's this nifty process called an active regen where the DPF gets really hot and cleans while you drive.Yet. DPF’s need heat to clean themselves. there will be permanent build up after a while.
I do a lot of highway driving, B1S3 (dpf) egt’s around 680-760 cruising, and use a scan gauge for monitoring. I can watch the soot decrease on highway drives, via scan gauge, as the truck is in passive regen. I don’t anticipate issues because of the highway mileage and have not noted any signs of frequent regens, prolonged regens, or excessive dpf soot loading. I did have one or two regens occur at about the 350 mile interval but that’s it.Yet. DPF’s need heat to clean themselves. there will be permanent build up after a while.
I believe it was at the beginning of 2023 when he bought the F450 Dooley. They were both test drove at the same time so I’m assuming 2023.I'd like to know how old that F350 was as that may shed light on that story unless he test drove two new ones.
The 2025 Rams loose basically all passive regen because they moved the SCR in front of the DPF. So the regen distance will decrease and they will most likely have more DPF problems with the DPF behind the SCR vs in front of it.I daily my 2500 6.7 and have had zero emissions related issues. I don’t even tow (yet) and drive around 16k+ miles per year. My average regen is about 650-900+ miles between regens, usually.
There isnt a physical level sensor. DEF level is monitored exclusively by an ultrasonic level sensor since it can freeze during the winter.There's a tank. There's a module (in the tank) that consists of a pump, a level sensor, and a heater.
Correct. As I said. There's a level sensor.There isnt a physical level sensor. DEF level is monitored exclusively by an ultrasonic level sensor since it can freeze during the winter.
