F350 or Ram
The Ford is still using the CP4 fuel pump. I don't think it caused as much problems as it did in GM and Ram trucks but it would be a concern for me.
The GM puts down the least power on paper, but they intentionally concentrate on power under the curve instead of peak power numbers, so real world towing performance is pretty much on par with the other two trucks (probably not the HO from Ford).
If I had to purchase today, I'd probably lean in the GM direction but you'd have to check their seats as they are the least comfortable. They ride nice though with the IFS.
Currently have three Super Duties. Newest is a 2019 with a 6.7l diesel. The 2019 has been near trouble free, with the exception of a DEF fluid heater line.
A co-worker purchased a 2024 Chevy one ton. I was amazed at how well built the truck was. I'm addition, I found the Chevy looking much more serviceable (visually), than the Ford.
Without hesitation, I would include a through inspection of Chevy's 2025 one ton trucks as part of a one ton truck purchase analysis.
I don't think frame is an issue what so ever. Guys are putting 500k miles on these trucks doing hotshot all day everyday with our frame issues.
Hotshot loads typically are weighted directly over the rear axle via a gooseneck, not sure how relevant a hotshot configuration is to test frame strength.
Hotshots provide awesome data points for full size truck purchasers, not sure frame strength is one of the many data points a hot shot configuration provides.
I would love to see extensive research from hot shot drivers with 500k miles. I would gladly pay for the report.
Watch pd diesel on YouTube. Guy consistently gets him trucks to 500k miles
1) Company drivers are hard on trucks. OTOH, hotshotting can be largely highway miles which greatly benefits trucks.
2) Those are 4th gen rams, specifically 2013-2018 3500s with the Aisin/HO.
3) If you watch enough videos, you pickup clues that his trucks may have had some modifications.
Not to speak for him, but IIRC he had a bad run with the 2022+ models at low miles, has experimented with fords but thinks they're too powerful to survive company drivers, is hopeful for 2025+ ram.
He also maintained the heck out of those trucks. They did about 100k a year on them, so for instance, every year in the fall they'd dump coolant and do a water pump. 100k water pump pm. Boom. Costs less to PM parts in your shop than to have them fail far from home even if you replace them less often.
  • Like
Reactions: GON
Few things to consider. Ford 10 speeds are still having issues.
Everything has been talked about except body rot. If you have harsh winters, there is a huge advantage to getting the ford aluminum body. It will not rust or corrode. Not even the most field beat pieces of junk have corrosion.
Dodge also has the longest running classic body which you can see the edges are starting to show the die's and stamping machines are reaching end of life. However this is a very good thing. Body parts will be very plentiful should you get into an accident or have a rust issue.
As for GM, I cannot comment. Nobody in my family has them.
Was just talking about this with a buddy yesterday. I would get the new 2025 Ram 3500. With the correct options they look fine. For me either Big Horn or Laramie with sport package painted bumpers.
Ford is great too but not a fan of these new super duty headlights. Too bug eye for me. They only seem to look right in high trim levels and certain colors.
