Just an FYI:
The new tire sizes for F1 starting in 2022 are 305/720R18 and 405/720R18. That's the equivalent (more or less) to 305/45R18 and 405/30R18.
The old sizes (2021) were 305/670R13 and 405/670R13 (305/55R13 and 405/40R13 - more or less).
I note with interest that the front tires in both cases have a significantly higher aspect ratios. I suspect that is done so the front has more compliance, but that also means the fronts will be more imprecise than the rears. Remember how some folks had trouble with the rear snapping into over steer?
So what do I think is going to change as a result of the new tire? More snap oversteer! Less damage due to curbs! The mechanical suspension will need to be softer - and that means more tuning opportunities! Getting brakes up to temperature is going to be harder, but you won't see as many on fire!
