F-150 Oil
Originally Posted By: Trav
Originally Posted By: omnia
I'm told by several local mechanics that Pennzoil makes engines dirty and will cause early failure.
Find better mechanics.
+1
The good old dirty Pennzoil that destroys engines story.... no wonder it's the #1 selling brand of motor oil.
As posted any name brand oil in the proper viscosity will be just dandy.
Please help me. I just recently purchased an '05 F-150 with a V-6 4.2L engine, automatic, 2 WD. It has 89K on it. Seems very solid and runs great! I do not know what the previous owner ran as far as oil goes but the dealership (it was Chrysler not the local Ford dealer) used Pennzoil when they changed it. It had been sitting about 6 months before I bought it. I'm told by several local mechanics that Pennzoil makes engines dirty and will cause early failure. Please tell me what oil would be good to use in this truck for the remainder of it's life.
Your local "mechanics" have been smoking too many left handed cigarette's. Time to replace them.
The Pennzoil meets the Ford specifications. The danger to the engines, as Trav points out, is misinformed mechanics, and not Pennzoil conventional, which is fully approved.
+1
Our fleet mechanic at work yelled at me for putting Quaker State Conventional in my fiances Impala. He told me Pennzoil is junk and it's going to wax everything up in the engine. He saw me put Shell in my truck and told me it was great stuff. I don't think he realizes theyre all made by the same guys hahaha. He says Mobil 1 is the only thing anybody should use.
Mobil Super High Mileage 5w30. Great synthetic blend. Has seal conditioners, but is not a higher viscosity like most High Mileage oils.
The thing I have learned here is that really any oil is good as long as it meets the proper standards. No reason to put the high end Royal Purple, Mobil 1, etc., in it. I assume it would be good to just take it to the Ford dealer and have them change it to the Motorcraft synthetic or should I stick with Pennzoil?
You may want to run 5w30 and I can understand why, but it's not the grade spec'd so I would run Castrol GTX 5w-20. It's almost as thick as 5w30, and it lasts like a synthetic.
If you plan on doing it yourself, get whatever oil that's cheap and meets the specification, which would include Pennzoil, and have at it. If you like or need to get it done by someone else, there's nothing wrong whatsoever with having the dealer do it with their Motorcraft oil.
+1.
If you notice in my signature I am using Pennzoil Platinum 5w20. It was such a great price at Walmart and $15 in rebates, they are practically paying me to use their oil. They were out of 5W30 so I bought the 5W20.
If you do it on your own, I highly recommend the MC FL-400S oil filter. Walmart sells them for. $3.97 each.
We don't get quite that lucky, and our Walmarts don't carry MC oil or filters, unfortunately. If one does prefer to get the work done for him, the Ford dealers up here are decently competitive, at least.
