F-150 4.9 Ow20 synthetic??
San Antonio, TX
So I know ford back sped'd the 4.9 ford to 5w20 motor oil, but there shouldn't be much of a difference between 0w20 and 5w20 should there? Reason I ask is I am using the mazda Idemitsu Ow20 in my mazda and I could use just one type of oil and keep it in my inventory. What do you think? would 0w20 be too thin for the old 4.9? I have been using 5w20 with good results.
Motor oil always thins out as it gets hotter. A 0W-20 doesn't mean it is thinner @ full temp than a 5W-20. They are both 20 weight oils.
In the case of amsoil, their 5W-20 is thinner than their 0w-20 @ full temp, but both are still 20 weights.
I would use a 5w40 since you live in TX and your other vehicle is using it as well.
I would lean towards the 5w40 as it supposed to be a working vehicle and in a temperate part of the country, well was a bit of a cool front there for couple days:)
But he said 5-20 was giving him good results.
well when I say good results I mean it didnt leak all over the place or get consumed or have a wonderful UOA. I never did one. I will say that on rotella T6 it sounded like a quiet diesel when cold for some reason.
But is not a oil recommended by any of the other vehicles. He wants a common denominator oil. I would just go to Walmart and get a 5 quart jug when the time comes and not worry about inventory.
To answer your question E150GT, 0w20 or 5w20 will both be fine. No difference until you get to cold temps that you'll never see in TX.
That said I agree with using the originally specified oil; older engines plus 20 weight....dunno.
That Ford 300 straight six was basically designed in the 50's and 60's. It's an OLD design. A 0W20, in Texas, is a TERRIBLE choice for that engine. If you want a common shared oil, use the same Rotella 5W40 as you use in your other car.
The 300 6 is nearly indestructible as any engine ever mass produced, 5w-20,0w-20, 5w30, 5w-40, 20w-60 and whatever else one can come up with will work fine.
If you're using 5w-20 and want to use 0w-20, or viceversa no problem as they're interchangable for your application.
I'll just go ahead and post my response again, since a bunch of banana throwing monkeys have inundated this thread with absolutely comical replies, ie recommending a 0W20 in this old engine design, in Texas.
OP, go buy some Maxlife 10W40 and give that old engine a proper viscosity, that it craves, and deserves.
I would use Shell Rotella T6 5W-40, 5W-20 is a bit thin in texas for that old school 300 I6, even if they do indeed have a reputation for being extremely durable, some say it is the best engine Ford ever made.
Wasn't 5W/10W-40 perfect for Texas heat in 1995? Still is today! Save the 0W/5W/20s for further north... a-lot further north / a-lot newer vehicle.
Originally Posted By: simple_gifts
Vehicle is a 1995, not a 1975.... lol
That engine family was built from 1964 to 1996. It's an OLD design.
