Exxon Synergy Supreme+ premium gasoline
Texas
In my area I use top tier gas, specifically Exxon Synergy Supreme+ premium gasoline 93.
Saw this and was curious. Is this possible or mainly marketing?
Friction modifier – the ingredient protects your engine by reducing wear and tear by 30%.‡‡ (Benefit available only in Synergy Supreme+ premium gasoline)
Wear and tear on injectors, etc?
Found is interesting nonetheless.
Only on their premium gasoline. Shell's attitude is in all grades.
Would please provide a link to that. From what I can find, it’s only in their V-Power Nitro+.
https://www.shell.us/fuels-oils-and-coolants/shell-fuels/shell-v-power-nitro-premium-gasoline.html
Also watch this video from LSJ where he talks about using premium fuel to reduce engine wear.
All grades of shell gasoline are top-tier; the premium v power has n't even more additives. I usually use the mid grade silver gas at Shell which I assume is a mixture of both the premium and the regular so the mid-level should have a pretty good dosage
My guess is a UCL copycat similar to Shell V-Power Nitro+
Mid grade is the gas most likely to be mis labeled on purpose for profit I would mix my own
ExxonMobil Research Engineering developed Synergy …
(something like 7 additives) …
I was running the mid before the price spikes …
Jeep back to RUG, PEA at OCI end, and TCW3 …
Only the Mustang gets Synergy …
Looks like Exxon 93 is going to be my top choice, knocking out Shell
For me, I go with BP primarily and Quik-Trip as my second option. There are no Exxon stations that I know of in my area, but there are a few Shell stations.
I consistently get 1.5 mpg more with Exxon. No mileage increase with Shell. So maybe the Exxon friction modifiers at work, but I use 87 and it says modifier only available in 93. I don't know other than the mileage increase.
My understanding is that mid-grades are a mixture of regular and supreme and thus mid-range also would have the detergent that you say only supreme has
