Does anyone know of any VERY thin spray wands to use with your typical undercoating gun? I’ve been using Fluid Film for 5+ years. Countless applications but the wands I got from Kellsport Products years back are too thick to get into a lot of the smaller drain holes typically found on body panels. They’re good for undercarriage but too thick for drain holes you see on the bottom door seams, rocker panel access holes (when you remove the plastic sill plates that many cars have), etc.
I’ve been forced to use the rattle can fluid film with the small red tips to get into such areas but it’s not ideal. They have extension wands for the rattle cans too which work nice, the size is perfect BUT the cans are very costly and the product is not the same consistently as the gallon Fluid Film, it’s chunkier and doesn’t spray as smooth or far.
This is the wands I got for my guns but would love to know if there’s something thinner:
https://www.kellsportproducts.com/18-Flexible-Extension-Wand-for-Woolwax®-PRO-gun-with-360°-nozzle_p_50.html
