You need to adjust the carb to get it to run correctly .I run 40:1 in my Stihl if I try to go anything richer it won't run. It's super picky about the oil ratio.
It recommends 40:1 so far no issues with it after five seasons.You need to adjust the carb to get it to run correctly .
I meant if you change the ratio to something richer or leaner.It recommends 40:1 so far no issues with it after five seasons.
I used to use Mobil 1 2T. That stuff has to be 15 years old or more isn't it? It hasn't been available in the US for a long time.I get the concern about rich/lean, but what intend to do is add just a tad bit more than the ratio specified.
No issues doing this with my stock of Mobil 1 2T (old stock).
The ratios with less oil keep everything cleaner too. Growing up, for whatever reason we had some tcw-3 that we would mix for the two stroke stuff. It was a heavier ratio of oil, probably 32:1. It always was damp at the exhaust.
Yes NOS. I have a lot of it. No worse for use as far as I can tell on a whole bunch of two stroke stuff.I used to use Mobil 1 2T. That stuff has to be 15 years old or more isn't it? It hasn't been available in the US for a long time.
Just always run 32 through 40 to 1. I can find no reason to run 50:1 other than emissions. If you're fouling plugs faster with 40:1 then you're running way too rich and need to have the carb adjusted.I have a weedwacker coming my way next week ( hopefully)
It calls for 50-1 mix. Anything wrong with adding more oil for the first tank of gas or so? 32-1 or 40-1?
I have ordered an echo srm225. Due to our emissions laws it can't be sold here so we will see if the sale goes through. Plan B is a road trip to Home depo in Bullhead Az with a side trip to oatman.
My oil is Torco GP-7. Had great luck with it.
Why no still grey bottle? Pretty sure that’s what they sell to lock in the warranty…Just always run 32 through 40 to 1. I can find no reason to run 50:1 other than emissions. If you're fouling plugs faster with 40:1 then you're running way too rich and need to have the carb adjusted.
The only oil you shouldn't run is the Stihl oil in the gray bottle.
Any CD rated 2stroke oil running 40:1 will do nicely and your weed eater will love you long time.
Its an ester base and is making really bad combustion chamber carbon deposits.Why no still grey bottle? Pretty sure that’s what they sell to lock in the warranty…
I found that my Stihl stuff runs better on the Amsoil Dominator that we use for dirt bikes. Clean exhaust and starts with 2 pulls.Its an ester base and is making really bad combustion chamber carbon deposits.
There's posts on here about it.
It costs probably 4 times as much as the next best top quality CD rates oil so I would hope so.I found that my Stihl stuff runs better on the Amsoil Dominator that we use for dirt bikes. Clean exhaust and starts with 2 pulls.
Cost difference is in the noise for the amount that I burn up in a saw or blower when I already have a gallon jug of Dominator. They really run and smell good when using VP race gas (only when I have run out of 91 pump gas).It costs probably 4 times as much as the next best top quality CD rates oil so I would hope so.
Clean exhaust and starting with 1 or 2 pulls is more of a function of carb tuning than anything the 2 stroke oil does.
I ran the much cheaper redarmor oil and kept the same spark plug in my echo saws and redmax weeder for 3 to 7 years running 40:1 most of that time.Cost difference is in the noise for the amount that I burn up in a saw or blower when I already have a gallon jug of Dominator. They really run and smell good when using VP race gas (only when I have run out of 91 pump gas).
I would guess a cheaper oil would eventually cause hard starting and plug fouling.
Yep, my dad remembers mixing 30W oil into their old lawn boy gas in the late 50's.When I was kid back in the 1960's and 1970's most people ran 20:1. Some 18:1.
I mowed a lot of neighborhood lawns. My dad bought me a Lawn-Boy commercial push mower. Cast Al deck, 1 gallon tank, steel ball bearing wheels, industrial 2 stroke motor. We mixed 20:1 with 30w motor oil.
My dad was still using that mower into the new millennium.
Glad it works for you, but from what I can see Red Armor isn't any cheaper. I've heard good things about Red Armor but it costs more than Dominator and I am not running Red Armor in a YZ250 or KTM300.I ran the much cheaper redarmor oil and kept the same spark plug in my echo saws and redmax weeder for 3 to 7 years running 40:1 most of that time.
I even dump old 2 stroke gas in my 4 cycle lawnmowers and the plugs still don't foul out. Yeah that's carb tuning more than the oil.
