Extending OCI in Oil Burner
Originally Posted By: BrocLuno
Do you have access to BG products? I'd throw a can of BG-109 EPR in there with the HDEO and see if it does not free up the rings a bit. Might lower your consumption a bit ...
I don´t have access to that products, but I hope the HDEO helps to clean the rings
Adding oversized filter will help with volume of system (cooling, cleanliness, etc.). Can't hurt, and is usually same cost
I´m currently using an oversized filter that is 1/2" taller
