- Joined
- May 5, 2018
- Messages
- 27,328
Yes sir...can get expensive too.V8 PDS? Yeah.
I think some MB and BMW V8 gasoline engines are close to 12qt.
Does Aral still have reputation like in 90’s being really high quality?
If that's the normal interval specified by VAG then yes it'll do that just fine since it's VW approved.The Quaker State 5w40 that's on 'CLEARANCE' at some Walmarts meets MB 229.5....it also meets VW 502/505.
My local Walmart has several 5 qt. jugs but it's still $18.97. I'm thinking of buying it for the VW Touareg 3.6 that my relative owns.
Can I assume this oil is a 10K oil in that application? The sump is 7.1 quarts according to what I've read online (I haven't seen the OM yet).
Thanks blu....I'll have to read the OM and see what VW specifies...the Touareg's owner isn't exactly a slave to maintenance so I'm hoping it is a 10K interval...If that's the normal interval specified by VAG then yes it'll do that just fine since it's VW approved.
Based on what.Better oils available in Wal Mart.
I’d be more worried about the filter going that long.Any oil with MB229.5 approval should be capable of up to 15K OCIs.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
With that long distance highway driving I don't see a major problem.
MB engines haven’t had that problem. But I can’t speak for the newer 4 cyl engines they are putting out.Mobil 1 0w40, Pennzoil Platinum Euro 5w40 or castrol 0w40. All available at Walmart I believe at a great price. Money is no object and you want that "OUUU" feeling? Motul 5w40 Amsoil Euro 5w40. Look out for calcium numbers in Mobil 1 0w40 Which is a LSPI isssue, however many say that's an issue for smaller engines and that zinc is an offset to that issue, something Mobil 1 has plenty of. Someone chime in here.
Hmm...Based on what.
And on my M272 engine, it's not a regular canister filter, uses a fleece cartridge filter which is supposed to be some synthetic material. Some people have cut them open easily enough afterwards and they look the same as when they went in, just covered in oil. Their original interval was 13k.MB wouldn't spec that OCI if they hadn't designed the filter appropriately.
I think 13k would be a cinch with that spec oil and the large sump capacities.It's pretty standard on Mercedes. They've been doing 10k oil changes for years. Used to be 13k on my 2008 but I guess that was too long for some people so they revised it down to 10k. They do use a lot of oil though, one specs 8.5 quarts and the other is 7.5 quarts.
Yeah but I'd still prefer the Castrol. Higher tbn doesn't always translate to better retention.MB 229.5 is a long-drain, high performance oil spec - one of the toughest specs out there....
Mobil 1 0W-40has the highest TBN of any 229.5 oil I know....
(Castrol 0W-40 is barely even the minimum 10 to achieve spec)
Not always - but in this case it does.Yeah but I'd still prefer the Castrol. Higher tbn doesn't always translate to better retention.
Mobil1 bumped IMO TBN as 0W40 always had issues with retention. Also that uber high SAPS is not best bet in DI engines.Not always - but in this case it does.
Mercedes Benz does not have problems with high saps oils used in their DI engines. They offer the best engine protection - in 229.5, engine protection takes precedence over exhaust treatment equipment protection.Mobil1 bumped IMO TBN as 0W40 always had issues with retention. Also that uber high SAPS is not best bet in DI engines.
