ok i asked you guys for help on throttle body cleaning before, and i am thankfull. i used sea foam and it was great.
well i had another thought. my car is a 4 cyl engine and of course has a 4 channel intake manifold. if i were to spray seafoam while it was running...most of the sea foam would go into the first hole and the second hole...barley any would get into the third hole and the 4th hole, right?
would it be wise to actually turn off the car and individually spray each of the holes? like put a bunch of stuff in each hole? if so, how much...
my car is a 1991 honda accord 2.2l engine nearing its oil change. its an old car that had an intake leak and i only found it recently, with a dirty dirty throttle body.
thanks for ur time.
[ September 22, 2003, 01:23 AM: Message edited by: digitaldrifter91 ]
thanks for ur time.
