Originally Posted By: lomez
So I still can't figure out why, assuming most all of the "thick" ATFs have the same viscosity......but some have more FMs than others, and some are conventional oil while others are group III......why would using a synthetic with all the FMs not work as well or better than anything else?
In general the better the base stock the better the ATF. However, the frictional characteristics of different specifications are not exact matches. It is not merely a question of quantity but quality - the friction characteristics are charted graphically and some, like the Chrysler ATF+4, have different “shapes”.
For example, why would using ATF+4 in place of say T-IV be a bad thing? It's the same viscosity.
First of all, they are not the same viscosity. The Brookfield viscosity of the ATF+4 does not line up with Toyota T-IV.
ATF low temperature viscosities
Second, the curve of the frictional characteristics of ATF+4 is different than other ATFs.
Here’s the short summary. Transmission manufacturers develop their ATF specifications without regard to the aftermarket. This is the same reason we have hundreds of oil filter specifications instead of two dozen.
If you buy a vehicle and it’s under warranty, it behooves you to use whatever is specified since paying for automatic transmission repairs is no fun. Generally the manufacturer can determine whether you used a non-specified ATF in the event of a warranty claim.
After it is out of warranty you can do as you wish. In many applications under normal conditions switching ATFs appears to cause no problems. For example, many dealers have used ATF+4 and its predecessors in Mitsubishi, Hyundai, and Kia transmissions with no apparent ill effects. A number of aftermarket suppliers have produced multi-application ATFs and purport to stand behind them.
Would it make sense for the industry to move towards some standardization?
Sure.
Is it going to do so?
I think it is unlikely at the OEM level, but the aftermarket appears to be moving towards consolidating similar specifications.
