- Joined
- Nov 29, 2009
- Messages
- 10,258
I think the bearings will go before anything else. The gearsets will probably last forever imo as long as the fluid is changed and it doesn't leak out.
The bearings experience very little load. I'd say just the opposite. The load between the ring and pinion is significantly greater when accelerating.I think the bearings will go before anything else. The gearsets will probably last forever imo as long as the fluid is changed and it doesn't leak out.
Which is the lifespan of most vehicles-yes I know there are exceptions.With your normal average auto or light truck, I would expect 250 -300-K before any issues provided fluid is changed at least every 75k
The differential is probably one of the most durable items on a vehicle. Even with minimal care, it likely will outlast the vehicle.I think the bearings will go before anything else. The gearsets will probably last forever imo as long as the fluid is changed and it doesn't leak out.
I usually have to stop every other intersection for a red light. I think they have them timed for people that drive 10mph over the speed limit, because when you're slower at accelerating, towing a trailer or whatever you practically have to stop at all of them. So you're accelerating to 50-55 just to stop again and start the cycle all.overWe had a truck getting serviced at our shop that was used by the city to upkeep the side of the roads, it drove a lot in 1st gear, a lot of stop start. That blew up it's rear differential/final drive early. But stop/start and always in low gear (tremendous torque being applied) is a worst case scenario.
Vehicles going down interstates is the easiest on differentials and final reductions.
If you drive like a sane person, yes I was reading an article about how the rear differential is overlooked now by vehicle manufacturers. We still use the same rear differentials we did in the 90s and now vehicles are putting 400hp through them from the factory.The differential is probably one of the most durable items on a vehicle. Even with minimal care, it likely will outlast the vehicle.
