Exhaust valves have hydraulic lifters - do you adjust intake valves?
st louis, mo
I recently picked up a Honda Accord Hybrid with 250k+ miles. One thing I learned after I bought it, is that this model has hydraulic lifters on the exhaust valves but the intake valves are adjusted manually.
Do you think I should adjust them? I suppose there's not a good reason not to. I have always been more concerned by exhaust valves (burn if too tight) than intake valves.
It can't hurt anything and pulling the valve cover can give you a good idea of how clean the engine is.
You don't even really have to mess with them unless they are out of spec. I did the valves on my mom's 2011 Fit right at 100k miles, and most were still within spec. It was good to know the engine was spotless inside though, which I kind of assumed since my family bought it brand new and it has always been under my care.
I personally believe the suggestion to adjust intake valves is more for a reason to inspect the camshaft to make sure it is broken in properly.
When I was involved with camshaft design, I saw the blueprints required a maximum roughness after finish grinding, but a minimum roughness after phosphating to make sure it had enough phosphate. It is the phosphate that helps ensure a good break-in.
It better be broken in at 250k miles!
I'm interested in your thoughts about Honda camshaft problems. I've seen a lot of worn Odyssey cams (including my own 2010) and also some K24 cams on here. What do you think is the cause?
Is it a cam on tappet or follower, or is it a roller follower design?
Intakes need adjustment far less often than exhausts. I wouldn't even crack the valve cover, especially if they were shim under bucket.
