Exelon shuttering Oyster Creek Nuclear
OVERKILL
$100 Site Donor 2021
Ontario, Canada
The oldest operating Nuclear power plant in the United States, the tiny (636MWe) Oyster Creek facility, which commenced operation in 1969, will end its life having provided 50 years of power generation, retiring in 2019. It originally had its operating license extended until 2029.
The site produced roughly 4.6TWh (4,600GWh) a year and employs ~600 people directly, giving it a staff to output ratio of 1:7.6GWh.
Over its lifespan, this facility will have produced ~230,000GWh.
New Jersey has invested heavily in PV over the last decade, reaching an installed capacity of 3,260MW as of the end of 2016, which yielded an output of 2,746GWh. Given a 20 year lifespan, and not accounting for degradation, that PV, which includes industrial and rooftop, will produce approximately 55,000GWh during its lifetime.
One of the primary issues pertaining to the operating costs of nuclear in the United States is the staff to output ratio. That is, a nuclear facility requires security and significant operational staffing, which is the primary expense. Since staffing does not track linearly with installed capacity, larger facilities with higher output are generally in a better position to be cost-competitive.
To draw a comparison to a newer US Nuclear plant we could look at Watts Bar, which has an installed capacity of 2,300MW with its two units producing 13,650GWh/year with a staff of 1,000 people. This gives us a much more favourable staff to output ratio of 1:13.65GWh.
For a Canadian comparison
- Point Lepreau is our only operating single-unit site with an installed capacity of 660MWe producing 5,000GWh/year. It has a staff of 470, giving it a staff to output ratio of 1:10.6GWh.
- Darlington Nuclear, our 4-unit site with an installed capacity of 3,512MW producing 26,000GWh/year. It has a staff of 2,600, giving it a staff to output ratio of 1:10GWh.
- Bruce Nuclear, the 8-unit CANDU has an installed capacity of 6,288MW and produced 49,019GWh in 2017. Bruce employs 3,800 people, giving it a staff to output ratio of 1:12.9GWh, a bit lower than Watts Bar, but better than the other two. Of note here is that the Bruce site is not exclusively Nuclear. There is an ethanol plant as well as a marijuana grow-op on the expansive property.
I would expect, going forward, as gas pushes other thermals out of the market, to see these smaller nuke plants to be the first to go, particularly ones that are extremely old like Oyster Creek.
It will also be interesting to watch, going forward, what the required staffing will be for SMR's built as stand-alone. Currently pending new builds in Canada are both at already-staffed locations (Point Lepreau) skewing the numbers. SMR's are advertised as requiring far less staffing, so it will be interesting to see how that pans out in real-world application.
Originally Posted By: loneryder
So what are PV's and SMR's??
PV = photovoltaic; solar
SMR = Small Modular Reactor: A new family of Nuclear reactor designs, mostly of the molten salt variety, that are modular in nature (hence the name) and designed to be smaller and significantly less expensive to build. Sizes range from 80MW to 300 per unit for the most part.
Exelon threatened to shutter two nuclear power plants (Clinton and Quad Cities) here in Illinois, until the state (which is already in crushing debt) coughed up subsidies to keep them open.
Now they're threatening to shutter two other nuclear power plants... Dresden and Byron.
It's pathetic.
Clinton was started in 1975, and had massive cost over-runs, and finally came on line, 12 years later in 1987. 12 years to build a plant with 1 reactor.
The original budget to build it was $430 million. Instead, it ended up costing nearly 1000% of that... the final cost was $4.25 BILLION.
Originally Posted By: 4WD
Do the guys from the control room get to pick a bit of that pot?
I don't think so, LOL!
That’s probably a good thing …
It's pathetic.
Yup, that's a big part of what killed new builds. We had a similar issue up here. Pickering remained very close to budget, as did Bruce. Then Darlington happened and it went 2x budget and cost $13.6 billion. That was the primary reason the 2nd half of Darlington, Darlington "B" (as we tend to do them in 2x packs of 4 units) wasn't built.
There was a renewed plan to build Darlington B in 2008, and OPG got as far as getting all the approvals, site assessment...etc done and was ready to break ground when McGuilty pulled the plug on it, instead opting for the $38 billion Green Energy Act, which has been punishing the province ever since
It was worse for Braidwood and Byron, correct? I worked as a student/summer engineer for Commonwealth Edison during the construction of those units (got to tour inside the containment vessel once) and I remember the enormous sums of money the company was spending to meet ever changing regulations.
It sucks. I work at Indian Point and Entergy is shutting down our two units. We generate over 2000MWe. Andy Cuomo is a big part of why we aren’t profitable since we spent tens of millions of dollars fighting NYS to stay open. The NRC was willing to give us a license but Cuomo and River Keeper kept finding issues to delay us. Entergy finally gave up after long drawn out court battles and cheap natural gas prices started affecting the bottom line.
Andy is following in his dads footsteps. Mario Cuomo closed Shorum in Long Island right after they finished building it. Andy is trying to do it to Indian Point now.
Entergy owned James A. Fitzpatrick in upstate NY. It is staffed by 600 employees and is located right next to Excelon’s Nine Mile Point. Entergy was losing tens of millions each year at the site and decided to close it down recently. Cuomo stepped in and tried to stop the closure. That area of NY had booming industry back in the day and that’s why nuke plants were built there. However, jobs and companies moved away so that area has a surplus of power but low demand. He wanted Excelon to buy it to stay open so he offered all nuke plants in NY credits except for Indian Point. Entergy sold to Excelon.
Now we are scheduled to shut down for good. Unit 2 in 2020 and Unit 3 in 2021. 1000 AMERICANS (SKILLED CRAFT, ENGINEERS, OPERATORS) UNEMPLOYED. And Andy Cuomo’s office considers it a win even though we supply 25% of NYC’s power.
NYS has a plan to achieve lower emissions but is losing 2000MWe of clean power. How will they make this up? With wind or solar??? No. Wind is unreliable for baseload like nuclear and solar requires lots of land and both require subsidies. So while Cuomo was busy shutting us down, he promised to replace the power and quietly supported the building of natural gas plants which are under construction currently.
Worst of all was how the news was released to the employees. We found out because someone from Cuomo’s office leaked the news to the press.
Nuclear is dying in the US but is thriving in China. Not too long ago, the polar vortex happened and gas line froze. The price for electricity sky rocketed and baseload plants kept the lights and made a killing doing it.
Unfortunately the people of NYC keep voting for politicians with no sense, who expect solar energy to work at night due to a government regulation. I feel for the disenfranchised upstate NY citizens.
Nuclear is not the only ones suffering! Coal plants are suffering as well!
Quote:
In May 2016, plant owner Dynegy said it plans to cease operations at unit 2 of its Newton power station over the next year. The company attributed the shutdown on the failure to recover the plants' "basic operating costs" in the most recent MISO (Midcontinent Independent System Operator) electricity auction
and all these natural gas "peakers" built around 2005 by Aquilia(defunct) are being used full time.
ssamaroo01,
What career field will you go into when you employer finally shuts down ?
If you have skills in the Nuclear industry, Bruce Power is hiring. The Bruce facility is planned to operate until 2064, and there are plans by the company to build SMR's. Not sure what's involved to get a Canadian work visa, but it may be worth investigating.
Thank you for that information. I will look into it. I wouldn't mind the move especially since my kids are young and haven't started school yet. Once that happens, I would like to stay in one area.
You are quite welcome! OPG is also hiring for Darlington, and they pay extremely well.
Pro's/cons:
- Darlington is slated to close ~10 years before Bruce in the mid 2050's.
- Darlington is close to Toronto/GTA so it is both very convenient and extremely expensive
- OPG is also keen on an SMR program and if the present administration does decide to build Darlington B, the site will be operational until the 2080's and beyond.
- Bruce is a solid 2hr drive from any major centre (Kitchener or Guelph), being on the shores of Lake Huron
- Bruce is close to Port Elgin and Kincardine, both of which are absolutely lovely and shouldn't leave you wanting for the sprawl of the big city
