Excessive oil consumption-'03 Mazda MPV
MD
All of a sudden I have excessive oil consumption on my'03 Mazda MPV (Ford Duratec 3.0). It went from using 3/4 of a quart in 5,000 miles to 1 quart in about 1,500 to 2,000 miles. I suspect a pcv system problem, but wonder if it could be something else.
Any ideas?
The PCV hose that comes up from the separator on the valley to the intake leak a lot, as does the hose that connects the valve covers with a tee on the air intake boot. Oil leaks are also common on the oil pan, valve covers and timing covers on these engines.
The van has about 96k miles. I have done almost all of the oil changes on it. It doesn't leak to my knowledge, or blow smoke. I think that I have 5-30 in there now.
I had all of the common leaks previously. Changed out the oil pan gasket and had some leakage from the timing chain cover, but that's all gone now, I think. All of those had a burning oil smell associated with them.
I, too, suspect the hose coming off the pcv valve. I'll see if I can get a look at it today.
I took the pcv hoses off and replaced the main rubber elbow connector with brass. I also replaced a short section of rubber hose at the pcv valve. Nothing looked really suspect, but I thought I'd eliminate all potential problems.
I found, though, that I had a vacuum leak at the Intake Manifold Communications Controller. I bought the o-ring seal and fixed it. Could the vacuum leak at the IMCC have compromised the pcv system?
