Hi all, thanks for the quick replies and useful advice in here.
More about the warranty, it's a 6 month/5k mile one so I still have around 2k miles left on that. I did go to one shop about the leak initially, but from what they told and from how its worded, it seems to only cover catastrophic failure of certain internal components of powertrain, engine is included. Now I don't know if this is worth trying to pursue, or running the engine real low natually from oil loss outside the OCI, however reading about the warranty company and how much they weasel out of doing any work, not sure if its worth the risk to try to blow up the engine, along with having my only vehicle out of commission for god knows how long that could take.
I'll try a heavier 5w/10w-30 and aforementioned additives for next change, that Valvoline Maxlife the consensus of best high mileage oils? I see the Castrol variants often too, dunno which brands are best or just a matter of opinion. Oil pan gasket too maybe since I have to drain the oil anyways and is probably crusty, the small leak does come from there but can't verify that is cause of leak. Any recommendations on a filter too? If this thing is the case of doing a perpetual oil change might as well get a good one.
Also mixing in some diesel and running the engine a while like someone mentioned earlier does that work? Sounds a bit terrifying to try
