Excessive Came Lobe Wear? (Pics inside)
NC
Good evening to all,
It just so happened that the cam lobe was facing upward toward the fill hole when I was looking in so I was able to get a good look. The cam lobe looks to have worn notches in it. See the pictures below. Is this something to be concerned with?
This is a Mazda 2.5L motor with 9,300 miles on the odometer.
Cam Lobe pic1
Cam Lobe pic2
Thanks
I would be very worried... but the dealership might say its normal for the cam to look like that.
That really doesn't look right, esp for the LOW miles. The wear across the lobe doesn't look even, nevermind that there shouldn't be any.
Is that the original oil? Looks really dark.
It isn't the original oil. The FF was drained at 3,200 miles and this is currently on the second fill of oil (Mobil 1 0w20) with 6,100 miles on it. I am following a 7,500 mile OCI as recommended for normal service.
I stuck an extended toothpick into the fill hole and I didn't feel a ridge...the toothpick glided over it smoothly.
How would the dealership even check the cam? They'd say it's normal wear. The motor has a 5yr/60,000 mile warranty.
Break-in wear?
Appears, if actually present, to be wearing to one side(notice the stroke pattern below in picture #2?).
Not sure if it's supposed to break-in like that.
Originally Posted By: vinu_neuro
Seriously.. you won't stick your finger in there and see it's something real or not..?
I don't think my finger will really be able to reach down there but I will try again tomorrow. I used a toothpick to go over the surface and I didn't feel any ridge...the toothpick felt as if it were gliding smoothly over that area.
I'm not ruling out that it could be a mirror like effect or a reflection of some sort...but it at least seemed to me to be some sort of discoloration.
Originally Posted By: ltslimjim
Break-in wear?
Could you please elaborate on pic#2 and the stroke pattern?...I am curious.
To the naked eye, I am untrained by the way, it appears one side of the lobe is getting 'rounded off', perhaps it's a mechanical issue or normal...IDK...but it appears that it's getting worn by whatever it's down-stroke meets with. Normal? Abnormal? IDK.
Again, it's if there is actual wear visible or some sort of optical illusion. Picture #2 you posted shows this more, IMO.
Originally Posted By: Smokefan1977
given Gm's track record with cam wear I would have them look at this. My professional opinion is that this is an issue
So what does this have to do with a Mazda engine?
It appears the outer hardened case is wearing away. Are you hearing any ticking noise from the valvetrain?
Let me guess, you're manual recommends 0w-20?
Looks like what happens on some Aspire's. The plastic piece holding the rocker center can break which in turn causes the roller rocker to be off center. Not sure what retainer's the 2.5L use I'd say a spring. Maybe the spring is broke or mis-aligned.
