Velo -
I think that your crank bearing surfaces and bearings are soaked and wet with either oil. I'd bet $1,000,000 on it.
This sound like a viscosity or filter problem.
Let me give you the full story. Sorry for the long post. But I think it’s an important topic. Bear with me.
1. My Dodge Caravan 3.3 L. V6 has 150K miles and shot crank bearings. It was running on 5w30 conventional; I forget the type. Filter was Fram PH16. The racket on startup was painful, lasting 5 seconds or so. It went away as soon as the oil reached the crank bearings. The rod knock and main bearing rumble went away.
2. I put in Royal Purple 5-30 and another Fram PH16. The effect was magical. There was no more noise on startup. I thought RP was straight Grp V, but now I know that is not true. As I understand it, it’s a blend of Grp III and Grp V. I attribute the noise vanishing to the retention of the Grp V element by the bearing surfaces: crankshaft journals, mains, big ends. This retained oil stays there for those vital 5 seconds.
3. I had some work done by a mechanic. Without authorization, he drained the RP and put in bulk conventional 5w30; type not known. By coincidence, he replaced the filter with another Fram PH16. The appalling noise came right back.
4. I replaced the oil with RP 5-30. The noise went away immediately.
I think this qualifies as a controlled experiment insofar as only one variable was changed, viz., the oil. I realize that RP is disliked on this site, but it could be useful for high mileage engines. It seems to have just enough Grp V to keep the noise away. I accept that we don’t need 100% Grp V, and that as a practical matter it’s OK to blend it; say 20 25%; who knows?
Next, I’ll be using Redline 20-50. I’ll let you know how that works out.
FURTHER COMMENTS:
1. I’ve been using Redline 5-30 in two Mazda Miatas with noisy lifters. In one case, it completely cured the tappet noise. The other case is more intractable. It was once really loud and persistent, for say 45 seconds, then OK. Same story next day: 45 seconds or so of racket. But now it’s down to 2-3 seconds. I attribute this to the inherent cleansing effect of Grp V oils, cleaning the old gunk out of the bad lifter (from the steady diet of bulk dino from previous owners).
2. My younger son’s Saturn SL1 leaked oil atrociously. RP has completely cured this. Esters have natural seal-swelling properties. And Redline cured the cam angle sensor O-ring leaks on both Miatas.
3. I’m running Rotella T 5-40 (all Grp III) in my older son’s Corolla, 127K miles; no noise on startup; mostly short trips. I’m not obsessively ‘married’ to Grp V oils.
CONCLUSION
I’m fan of Grp V oil blends. But I don’t advocate them for everyone. They’re costly, and, for Redline, hard to source. For a new vehicle, I think one would run any good Grp III or IV; Rotella, PP, Mobil, etc. Perhaps, though, one would run Grp V at say 100-125K miles, if needed, depending on the noise at startup (which depends on engine wear, which depends on vehicle usage: short trips, long trips, etc, etc.)
Does anyone else on this site have any Grp V stories?
