If your car took 5w-30 and you lived in Canada and can get either one for free. Which one would you choose and why?
Quote:
Why would you use neither? They're both good oils, and you can't beat the price.
Quote:
Both good oils
I would use the Esso XD-3 0w40 for its cold flow. I use it year round in my Porsche. Nothing wrong with the Mobil but for canada the 0w of the XD-3 counts.
For your specific application (car that specs a 5w30) if i had the option I would use the Esso XD-3 0w30. It seems to be less commonly available at retail but the grade does exist.
Quote:
http://www.esso.ca/Canada-English/Files/Products_Lubes/IOCAENCVLESEsso_Xd-3_extra.pdf
can't beat the cold flow characteristics of XD 0w40...better than most 5w30s out there
BlazerLT,
you really should read the specs and manuf. info once in awhile instead of spreading lies
Quote:
Quote:
In an engine degined for a 5w30, the 0w40 is an incredibly thick oil that should not be exposed to a light duty oil pump in cold conditions.
It will cause oil starvation, enhanced wear, poor oil flow and rediculously high oil pressures.
That and longer warm ups.
Quote:
It's the cold cranking and pumping numbers that matter in really cold temps, not kinematic viscosity. The former and latter are not directly related. I.E. two oils can have equal kinematic viscosities at x degrees, but different pumpability and crankability at the same temp. The table above is based on these properties.
