Originally Posted By: PandaBear
I would say yes, it is more of a software or OS error. Since you already wipe out your old data, there aren't much additional test that will be helpful. Most of these test just try to recover data and partition that were corrupted. You probably don't need to worry much about anything else.
BTW, just out of curiosity what is the temperature reading on the drive? Usually HD is designed to tolerate up to 60C but the ideal is to keep it below 45C, and anything at or below 40C is sufficient and will not be beneficial to cool it any further.
If you feel like buying a new computer, that's fine too, but if you have already gone through the work to reinstall everything and don't want to spend more $, why bother?
Oh ok, thanks a bunch!
I'll check on the temp today. I looked at it yesterday but it hadn't been on long when I glanced at it.
As far as buying a new computer.
I'd really like to have one, but I don't want to spend the money either. Shocker, huh?
It is just that with this computer being 5-6 years old, no working battery (will run me $150+ from Dell, unless I want a knock-off -- which I haven't had good luck with) -- I have to stay within plug-in length of the outlet at all times, the computer can often get too hot to sit on your lap or even the couch, etc., the right mouse pad button no longer works (which means I have to carry a mouse around with me if I need it), and sometimes when I flip open the top the screen takes several extra minutes to appear or doesn't appear at all (maybe once every 10 or 20 times I turn on the computer).
I may be forgetting something...but you get the idea.
