Originally Posted By: Ken2
Originally Posted By: joflewbyu2
The EPA makes mileage requirements for the manufactures in essence to lower emissions. It does not rate each and every car emissions but sets a max limit it must fall below. The thinking is if a car gets twice the mileage it would use half the amount of gas in turn lowering emissions. It has forced manufacturers to use thinner oil to maximize the mileage so it would not get penalized for each .1 it falls below a set standard. Look in other countries and the same car uses thicker oils than the U.S. with their requirements.
Not so much in recent years. Foreign new car oil recommendations are getting closer to ours.
Also newer thinner SM oils with limited phosphorus and zinc
Wrong. SM oil is not thinner. SM oil is not lower in the zinc phosphate compounds unless it is also rated ILSCA GF-4. This is not an SM thing, it is a GF-4 thing.
that must be more fuel efficient than older SL rated oils are less desirable to ME. 10w-40 weight oils do not fall into the same requirements but are harder to find.
10W-40 always was a poor choice of oil. It is better now with modern viscosity index improves, but a 30 point spread is often asking too much.
As the EPA keeps requiring the manufacturers to meet longer emission warranty time frame the oils will keep getting reduced anti wear additives such as phosphorus and zinc - which poison catalytic converters.
Phosphorus does poison the cats, but the new tactic is for less volatile oils to keep the P in the engine. It likely won't go lower
What I remember as 5 year 50K miles is now 10 year 120k miles up from the previous 8 year 80k miles. Penny smart dollar foolish. There is more pollution to manufacture a new car and transport it - especially an import than keep a clunker on the road for the next 10 years. And considering the manufacture shoots for 10 years or 150k mile longevity, it all seems asinine. Sorry to rumble. Just a car guy that is in the industry and the more he finds out the more it kills the passion inside him.
Any more rants-without-full-information being held inside you?
Wow !! You put your foot in your mouth. Wake up. API’s new companion category to ILSAC GF-4, to be called SM. Vehicle manufacturers issued GF-4, the new gasoline engine oil specification, through ILSAC, the International Lubricant Standardization and Approval Committee, on Jan. 14. API’s Lubricants Committee is responsible for defining the SM specifications which will become a worldwide standard. It has 13 members: three chemical additive companies and 10 oil companies. Can you name a heavy weight SM rated oil? No you can't - hence SM rated oils are thinner than SL rated oils. That is a fact. The ACEA have a much stricter oil rating than the U.S. in wear. Check out this chart and input the different ratings for yourself to prove the foreign standards are so far away and better than the U.S. SM are towards "fuel economy & oxidative thickening" where as the A5/B5 is towards "wear & Sludge".
http://sas-origin.onstreammedia.com/origin/lubrizol/EOACEA2009/RP/PC/index.html
I never stated only conventional oil and no sythetic. Your 30 weight spread would only be related to conventional oil uses a bunch of additives to boost the Viscosity Index which synthetics would not need. Remember a conventional 5w30 oil is a 5w with additives to help it achieve a 30w when hot. A synthetic 5w30 is a 30 weight oil that flows like a 5w when cold. Being close to R&D you will discover wear & performance give way to grants and profits. Basically bribery to play ball with them or be shut out.
