I've had issues with the GM AFM stuff, 3 times in one truck and once in another.
My entries:
1. Ford 4.6/5.4L 2 valve that didn't have enough threads to keep the spark plug in the head, resulting in the spark plug being ejected (admittedly it was mostly a problem after a DIY spark plug change, but still).
2. Ford bested that with the 4.6/5.4L 3 valve where the spark plugs wouldn't come OUT due to carbon build up and a 2 piece plug design, remedied in later models. At least they weren't being blown out of the head? Oh, and the cam phaser issues.
3. Anything to do with the 2.5L Mazda CX-7. Nothing like having to half way remove the engine to get a serpentine belt replaced, and corrosion is everywhere. They built a trap door in the plastic pan underneath to drain the oil, nice, but not the filter? You have to completely remove the thing anyway. Changing a headlight becomes an all day affair, which apparently needs to happen about every 4 months. A/C compressor replacement takes less time if you remove the engine. It's buzzy, rides like a dump truck, has a baffling and horrendous interior. It literally does nothing well except fuel mileage, but you pay a penalty everywhere else. Easily our most regrettable purchase.
4. 1.9T Volvo S40 flame trap/PCV service.....They would block up and cause crankcase pressure, blow out all the seals, requires removal of most of the accessories, intake, hoses, etc. to service. VVT actuator would fail religiously, cam seals leaked like a sieve. Motor mounts require replacement often.
