Originally Posted by Snagglefoot
I was looking at the 3.5 liter DOHC ford engine as found in the Ford Fusion. People on the Fusion forum were complaining on the high cost of a water pump replacement and that some of these water pumps can fail at 85,000 miles. Ford books 10 hrs for the repair. The pump is nestled underneath the timing cover, not over top it like the older Vulcan 3.0 V6.
What other engines have quirky designs that would take an ordinary component repair and turn it into a 10 hr marathon?
Ooh, that would be the 3.6 V6 I had in my 2010 Traverse. Okay, maybe it shouldn't be an "ordinary" repair, but thanks to poor design, the 3 timing chains on 2009-2010 Traverses were prone to wearing out and needing replacement when the valve timing errors popped up. Can't be done with the engine in the vehicle, it has to come out. How does it come out? Not through the hood, but through the underside. That means disconnecting the propeller shaft, steering shaft, brake lines, A/C lines, upper struts, transmission cooler lines, shift linkage, and dropping the whole front frame; engine, transmission, and all. That's on top of the usual things to disconnect from the engine like exhaust, fuel lines, coolant hoses, and wiring harnesses. When it all goes back together, you have to bleed the brake system, do a front end alignment, and evacuate and recharge the A/C. Typically a $3000 or more job, and I've heard some folks have had to have them replaced more than once.
