Can you explain where those additives go?Troll bait?
No need. Troll confirmed.Troll bait?
I believe the answer to that is, yes.Troll bait?
I believe he stated that already. They “turn to vapor”.Can you explain where those additives go?
Zddp levels diminish over time. If your worried about it then change oil sooner or add some when the level drops. The trick is this: Oil is full of addatives that do not last as long as the oil. The good news is that you can tell exactly when additives fail. The level drops fast over about 500 miles. Might be a 1/4 quart or a half. That is when the additives break down and turn to vapor. Basically you can check your oil every week for months and then at about 3000-5000 miles you will see the small drop. That is when the addative are going and you change it. Try it and look for the sudden small drop.
No, as @RDY4WAR clearly detailed, they aren't. They do the opposite, diluting the additive package and decreasing the quality of the lubricant.Naah. Those little bottles of STP and oil treatment are great when you are half a quart low and milking it out till you can get home and change it.
ZDDP is the primary anti-wear additive and the largest by volume. VII polymers are extremely heavy and while cheaper ones can shear, they do not evaporate. Lighter fractions of the base oils can be volatized, and oil mist can make its way into the PCV system and result in some burning off, but this is dependent on engine and PCV/breather design.And yes, the additives do go away, and I specifically mentioned the additives are a lot more things than ZZDP but thanks for commenting and yes, you’re in information is valid.
ZDDP as an active antiwear molecule gets broken apart to create the phosphate layer on metal. Then it gets worn off so that zinc and phosphorus are floating around as who knows what but its not ZDDP anymore so even though the elements haven’t gone anywhere and will still show up in a used oil analysis the additive is getting used up over time.Can you explain where those additives go?
That would be a new one to me. After years of working in an industrial research laboratory, I’ve never seen the solute distill out of a solventI believe he stated that already. They “turn to vapor”.
Yes as you note, a spectrographic analysis is an insufficient analytical method determine compounds. And especially whether they are in an active configuration.ZDDP as an active antiwear molecule gets broken apart to create the phosphate layer on metal. Then it gets worn off so that zinc and phosphorus are floating around as who knows what but its not ZDDP anymore so even though the elements haven’t gone anywhere and will still show up in a used oil analysis the additive is getting used up over time.
So yeah if you knew the ZDDP was 80% broken down in your oil, adding a touch up could bring the levels back up to what they were when the oil was new but again how do you know how much ZDDP is left? You don’t with the type of used oil analysis we all use.
Now some additives will disappear over time like boron when it’s used as a detergent and suspend globs of crud that eventually get trapped in the oil filter along with the boron. You’ll see the ppm drop off considerably over a run.
Probably NMR which is what I suspect you meant to say. There was a post a while back ago that referenced a study that showed NMR could distinguish between active and inactivated ZDDP and gauge the effectiveness. You’re not going to image anything, but you are looking for deshielding of a central atom.I have no idea if companies do this but you’d need to put the sample in something like an MRI machine to identify the molecules in an oil.
Naah. Those little bottles of STP and oil treatment are great when you are half a quart low and milking it out till you can get home and change it. And yes, the additives do go away, and I specifically mentioned the additives are a lot more things than ZZDP but thanks for commenting and yes, you’re in information is valid.
Potato potato. You’re throwing something in a reasonably strong magnetic field and tickling it with radio waves, it’s the same physics.Probably NMR which is what I suspect you meant to say. There was a post a while back ago that referenced a study that showed NMR could distinguish between active and inactivated ZDDP and gauge the effectiveness. You’re not going to image anything, but you are looking for deshielding of a central atom.
Well sort of, you’re not obtaining an image and when I researched the hydrolysis of polyimide I didn’t use an MRI machine at the hospital.Potato potato. You’re throwing something in a reasonably strong magnetic field and tickling it with radio waves, it’s the same physics.
https://www.machinerylubrication.com/Read/764/nuclear-magnetic-resonance-additive
This page has a pair of graphs at the end and if you look past the poor data presentation, seriously how do you not make the two x-axis ranges identical or have any scale on the y-axis, you can see the additive fingerprint disappear in the used oil.
The additives vaporize and the level goes down is the rationale here?Zddp levels diminish over time. If your worried about it then change oil sooner or add some when the level drops. The trick is this: Oil is full of addatives that do not last as long as the oil. The good news is that you can tell exactly when additives fail. The level drops fast over about 500 miles. Might be a 1/4 quart or a half. That is when the additives break down and turn to vapor. Basically you can check your oil every week for months and then at about 3000-5000 miles you will see the small drop. That is when the addative are going and you change it. Try it and look for the sudden small drop.
Gotta be a hawk-eye or you’re gonna miss itThe additives vaporize and the level goes down is the rationale here?
No that is most certainly not the rationale.The additives vaporize and the level goes down is the rationale here?
There is a limit on ZDDP to be compatible with CAT's. What is high ZDDP? Euro oils have higher ZDDP (hence API SL designation still for many XW30 oils with Euro approvals).Pretty good video. So high ZDDP increases engine friction, poisons cats, and is not needed on roller cam engine.
On non roller engines, where you don't care too much about the cat, or engine friction, higher ZDDP will help wear.
As generally known. One of the reasons say on Mobil 1 5w50 Supercar which was designed for a non-roller engine, they ramped up the ZDDP and reduced the detergents to help wear.
Higher ZDDP can lead to catalyst poisoning if a lot of it ends up in the exhaust system. While less is required with roller followers and roller lifters, this does not mean that other areas may not benefit from slightly higher concentrations.Pretty good video. So high ZDDP increases engine friction, poisons cats, and is not needed on roller cam engine.
Depends on the non-roller application here. An old broomstick cam'd SBF or SBC doesn't require a whole heck of a lot of ZDDP to keep the parts separated. A cam-over-bucket application doesn't either, generally, unless it's design is such that it produces high pressure on a small contact patch (VW PD engines for example).On non roller engines, where you don't care too much about the cat, or engine friction, higher ZDDP will help wear.
Mobil 1 15W-50 was broadly spec'd for GM roller applications in Corvette and Camaro.As generally known. One of the reasons say on Mobil 1 5w50 Supercar which was designed for a non-roller engine, they ramped up the ZDDP and reduced the detergents to help wear.
