usually stalls after it was running fine for a while, it will start right up again with NO problem. When it stalls while I am driving I immediately put it in neutral and coast out of the flow of traffic ( which is sometimes hard as the power steering loses power).
I also have a CEL, that sometimes will go out after stalling, and I need to wait for it to come back on before I dare drive again or it will definitely stall ( in other words if the CEL light is NOT on I KNOW it will stall again).
When in park and I rev the engine it starts to stutter (lopes I think is the word) at higher RPMs ( not sure- car has no RPM gauge) , then when I release the gas pedal it returns to WELL below normal idling RPM's sometimes to the point of just nearly stalling out then regaining idle RPMs and sometimes it stalls out.
It is a GM 3800 series 1.
I cleaned the throttle body and MAF sensor ( using MAF sensor cleaner) , I changed the fuel and air filters ( both were changed a few months ago), I recently changed the plugs but NOT the wires. I changed out the vacuum lines yesterday, as some of them appeared to be falling apart.
The fuel pump sounds strong when I put the key in and turn to 2nd position w/o starting the engine, so I don't think it is a bad fuel pump.
I am thinking it is a TPS, IAC or coil pack or wires?
I am leaning against cam/crank shaft as that problem often does not trip a CEL?
Is it possible the fuel filter, even though only a few months old, is clogged? Are there bad brands of fuel filters that could cause this?
Any other ideas?
I haven't been able to get the code read for the CEL as it is the older OBD 1 or 1.5 and nobody will read it on the cheap or free.
Thanks
Any other ideas?
Thanks
