I have to chime in for all the picky haters. Some of you fancy yourselves engineers so let’s do some practicality quantifying.
I have this boat from 2010 I put about 80 hours a year on. A long life on a marine motor might get you to 2000 hours and that’s a stretch. That gives me maybe another 10 seasons, but technically, I’m already over the hill with it. Now if you’ve ever had to repower a boat you’ll know stretching that lifespan is a good proposition.
Ofc the primary reason for a repower is wear and the most urgent part of this is compression and blow by. That’s because for basically everything else that can go wrong normally you won’t have to pull the entire engine to fix it. But when it’s time to do piston rings or rebore it has to come out.
People keep saying “it’s temporary” etc… as if that makes it impractical. But for my money I might get another 10 seasons with it by reducing blow by (and therefore accelerated wear) and that’s half of another boat loan.
First of all, you will have to repower eventually if you keep the boat. But I want run it into the ground before the next upgrade.
For $10 a season or maybe $250 total, I make a best possible 25 year purchase into a 35 year purchase.
How. Is. This. A. Bad. Thing!?
In my experience boat motors and diesel engines (tractors especially) have greatly increased lifespans cause of this stuff. Some people try to knock it because it doesn’t offer a permanent fix, you know what else isn’t permanent… oil. How about spark plugs? Ever changed a fuel filter or an air filter? Changing those items has the same effect.
