Originally Posted By: tswm
(and check for the color of each as well as for too wide a gap prematurely induced possibly by antifreeze from out of blown head gasket),
To clarify, if it be a scenario where coolant leaks into combustion chamber, in due time that particular spark plug will be discolored according to the dye of antifreeze (on the ceramic housing), and more notably, you may see a rusted spark plug, more or less; I don't know if that's the case with long life platinums and iridiums but a few years ago I saw that a basic, cheaper spark plug exposed to blown head gasket problem had rust on the metal part, and the ceramic part was somewhat stained with green antifreeze color.
And this is stating the obvious, but because I recently saw a new car, less than 15K miles on the odometer, whose coolant reservoir was not emptied but dangerously close to doing so, therefore if you haven't done so, I would urge you to check the level in your coolant reservoir. Car manufacturers in general say an occasional pinging under load like going uphill is normal, but you're saying this is now happening regularly, which is definitely not okay.
And I've read of head gasket problems where combustion gases leak into coolant jacket.
Logically, these new MLS (I think it stands for multiple layer steel) head gaskets are designed to almost make impossible such problems in the latest new cars. It appears back in the days of producing aluminum head and iron cylinder block, many failures, according to my cursory reading that especially spurred the development of sturdier head gaskets. I assume that your motor is all aluminum.
There are different reasons for seriously bad engine pinging, and hopefully it's not any such head gasket issue causing your problem.
