Hello everyone. I have a few questions regarding what I should do to ensure that my vehicle is being stored properly. It is pretty much a garage queen that gets taken out on nice days only, but due to travel for work and other constraints I only drive it about once every 4 weeks. When I do start it up and drive it the car is taken on at least 30+ mile trips, and I never start it up and let it idle then shut off. I have heard that causes more harm than good with condensation buildup. When the car is not being driven it is sitting on a Battery Tender.
What I am concerned about is that due to it sitting this long and being undriven, is this causing any harm to the engine seals and upper half of the engine? By sitting this long it almost seems that the oil has probably back into the pan, and could be causing increase wear at initial startup.
I know that many people store their cars for months at a time during the winter, but is there a proper procedure for doing this before starting up the engine again? I know with older vehicles with a distributor you could prime the engine by running a drill. With modern igniton system vehicles that doesn't quite work. Is there a special procedure for priming newer vehicles, such as mine, before startup? Thanks for the help in advance
