Engine Louder With 0W-20 - Spec is 5W-20 - Bad?
Chicago, IL
Should I be concerned that my car's engine is a tad louder on idle with 0W-20 then when it had 5W-20?
Is there necessarily a direct correlation between engine noise and engine wear? And if so, is this absolute?
Now I do notice a very slight increase in MPG with the thinner stuff, and it might be trick of mind, but it seems the car has a tad bit more pep too. Maybe.
Thanks!
Honestly...I've never seen a MPG increase going from a 5 weight to a 0 weight. That number only really matters at startup.
Could it make your engine louder? Doubt it... Did you change brands? This is the more likely cause.
Just my two pennies.
No. used oil analysis will prove or disprove if any additional wear is occurring with the 'louder' oil. Usually there is no difference in wear between oils, even when quieter.
The oils are the same viscosity---they're both 20wt products. The 0w oil *might* offer a bit better MPG with cold starting compared to the 5w offering.
What oils are we talking here??
In my case, switching from Pennzoil 5w20 conventional to Mobil 1 0w-20 SM quieted the engine down a bit more.
Quote:
Just curious!
What 5W-20 brand are you comparing this to?
What brand is the 0W-20?
What vehicle & engine size?
Triple_Se7en, those questions might be a tad bit too personal for the OP.
I'm surprised no one has come back to this thread yet. I'd say the answer to your question depends on how raw your nerves are. Myself, I couldn't stand one minute of a noisy engine that's suffering from insufficient lubrication. I'd drain that 0W-20 out of there in one nanosecond and pour me in some 10w30; but that's just me, I'm extra sensitive when it comes to mechanical things.
I tried a 5W30 one time and my engine`s valvetrain was really loud after the engine was good and hot. Soon thereafter I got a Nissan Z32 FSM and it warns not to use a 5W20-5W30. It recommends a 10W30-10W40 under normal driving. It goes on to recommend a 15W40-20W50 if you drive extended high speeds. VG30DE engines definitely don`t like thin oils.
I`m currently running Mobil 1 15W50 and I`m switching to Royal Purple 15W40 here soon for my Winter fill (seeing our Winters average in the 70s).
Try Pennzoil Platinum 5w20 or 0w20 and see if you notice a difference. Take a sound bite before and after. SOME vehicles are just plain louder with M1.
