Originally Posted By: JZA70
I'm honestly leaning towards a lifter issue as this motor uses hydraulic lifters and because the knock noise is very intermittent.
I think that a JZ engine has bucket/shim lifters (not hydraulic). Thicker oil will help if it is a rod knock (rod knock is worse when warm/hot since the oil is thinner when hot). However, other things can cause knocking like loose pulleys, loose flywheel, etc. I would park the car until it's sorted out. Hopefully, a car that old isn't your daily driver.
BTW, I have a '91 Supra with a 7MGTE (I have a BMW and a Scion as well). Man, maintenance intensive (the Supra, that is). Constantly changing hoses, etc.
