Engine internal washing
Originally Posted by Superbenz
The job should be done at machine shop, they wash in a tank but the guy told me that I have to clean oil and water ducts again with a solvent.
My question is what kind of solvent to use?
I would think they have the solvent. Are they asking you to buy it?
More than anything else, make sure to clean the oil passages with a nylon tube brush, some form of solvent and compressed air.
[Linked Image from images.homedepot-static.com]
Hot tank at the machine shop. When home, soap & water with a set of engine cleaning brushes and rags. Immediately blast with compressed air, then follow with WD-40 on the iron parts (liners, for example) to prevent flash corrosion.
Originally Posted by bullwinkle
Hot tank is the best way to clean a machined block, followed by careful pressure washing.
Yes, the engine rebuild shop (or machine shop) should have a way to get the block (crankcase) very clean
Originally Posted by atikovi
I don't think the term "hot tank" has been used since the 70's. Some of you guys must be ancient.
There are ultrasonic cleaners and automated parts washers now. https://www.youtube.com/watch?v=VKt8Nz7c40w
I haven't been called ancient yet but I have driven cars with oil bath air filters, no power steering and manual chokes.
Have to add, hand cranked, to be called ancient.
