IMO engine hours is less than ideal for light duty cars/trucks. Simply put there are more accurate ways to do it.
"A novel microacoustic device determines the viscosity. This device utilizes the piezoelectric effect to electrically excite high-frequency mechanic (or acoustic) vibrations at a sensitive surface. When this sensitive surface comes into contact with the oil, the electrical device parameters, such as oscillation frequency and damping, are changed according to the oil’s mechanical properties, especially viscosity. Thus, the viscosity can be electrically detected by measuring these parameters. In contrast to conventional viscometers, which are commonly used in laboratory applications, the microacoustic sensor does not contain any moving parts. Furthermore, due to its small size, it can be easily incorporated into the multifunctional oil-level and condition sensor."
Pinging @kschachn to read this. A sensor which can determine viscosity!
https://www.machinerylubrication.co... of oil,the capacitance measures this change.
