A lot of you are quite fussy about the type of oil you uses.Maybe that's a good idea with some engine designs.An example,during WW2 the Germans devoloped usuable jet engines first primarily because they devoloped synthetic oil able to cope with the requirements of the jet engine.They has a shortage of critical materials so they couldn't build the engine around availabe lubes.
So,do you think some or all new engine oiling systems are designed around the properties of modern lubes?If you went back in a time machine to 1968 and bought Valvoline 10/40 oil and returned to pour into the crankcase of a 2010 engine...would engine life be comprmised?
I have two 1999 Jeep Cherokees.Both have the 4.0 inline 6,the basic design going back to the early 60's.I'm thinking this engine should be "easy" on oil being the lubrication and bearing design is 50 years old.And it was made to give a decent lifespan on the old oils.
Any thruth to this you think?
