2000 Mustang GT 4.6 Litre 5 speed manual.
Change my own oil at work like I have for years on all my vehicles. Changed the oil and filter on my son's Mustang yesterday. Folowing the change I started the engine ran it up to about 2500 RPM for about 10 seconds. Shut it down checked under the vehicle for leaks (none seen) let it down from the jack stands checked the oil level (via dipstick) and was on my way home.
I was about 3 miles form work on the freeway when I notice I had no oil presure on the oil pressure gauge. Pulled off the freeway on first off ramp and stopped engine immediately. A quick check under the vehicle revealed a massive oil leak originating from the oil filter area. Towed the car back to work and found that when I removed the old oil filter during the oil change the rubber gasket had stuck to the block and had not come off with the old filter. I did not notice this at the time and spun the new filter on with the old rubber gasket still in place.
After fixing the filter issue I refilled the engine with new oil again (Esso XD-3 0W-30) and started it. When I shut the engine off after discovering the oil leak it was running alright but was making a rattling noise (sounded like lifter noise). When I started the engine after fixing the filter and refilling the oil it made this sound again for a couple of seconds and then the noise disappeared and it seemed to be fine. I drove the car around a bit and it seemed (on the surface anyway) to be OK. It runs smooth with no noise at all.
Any thoughts on things I should check? Did I get lucky? Or could something be wrong that I just don't see right now?
Thanks
Thanks
