I bought an older GMC pickup from a friend. Got it really cheap. Wouldn't start, may have a bad fuel pump. He had let another guy borrow the truck. That guy ran it a little low on oil. My friend thinks it may have a stuck valve. I bought the truck just to see if I could get it running and then sell it.
Another friend, a mechanic, suggested changing the oil and adding a quart of transmission fluid in exchange for one quart of oil. I had planned to add a quart of Marvel Mystery Oil. Which one will clean the engine better and faster?
I also plan to run a quart of transmission fluid through the carb just in case the valve's are sticking. Thanks for any help you can give!
