- Joined
- Aug 9, 2022
- Messages
- 170
Can any of the resident engine builders recommend an assembly lube for doing a top end refresh (cams, cam followers, lash adjusters) on a 3.6L Pentastar?
Is your concern over wiping a cam? Isn't that more common on push rod engines without roller lifters? Would cranking the engine until oil pressure builds up help?They are OEM parts and don't come with any specific installation or break-in procedure. The section in the service manual for cam installation just states to lube everything with regular 5W20 engine oil, but that doesn't appear to be a best practice for brand new parts based on the engine building publications I have seen because regular oil won't stick to the parts as well or provide the lubrication properties of an assembly lube even when sitting for as little as a couple days. I would like to use whatever product is going to give me the best shot at a successful break-in, and have a higher margin for error.
Huh? Moly cam lube is cheap insurance. Pre-lube when there is a distributor driven oil pump. Not sure how the LS type engines can be pre-lubed.On a serious note, there are all sorts of products available. What they do is remain in place for a long period of time. Maybe years, while (for example) you finish assembling your AC Cobra replica. If you are going to repair and start the engine right away, use motor oil. It is very, very unlikely you need anything else.
Using grease or some magic lube is not necessary on most modern engines and the clay or lithium binders of grease don't belong in an engine. If you must, use something a bit more viscous than 0W-20. Maybe a 5w30?
Just a quick note about pre-oiling a recently overhauled/or replacement engine after installation. Get a $7 plastic pump for gear oil, use a vinyl hose (and zip ties) and pump a quart of oil into the oil pressure sending port. This will fill the oil passageways and result in near instant oil pressure on startup. Protecting your main and rod bearings.
