http://www.swri.org/4org/d08/Abstracts/GasEng.pdf.
Go to Page 11 of this pdf to see what the fuel economy test consist of.
Specifications
API category SL/SM and ILSAC GF-3/GF-4.
Objective
The objective of this procedure is to measure the
effects of automotive engine oils on the fuel
economy of passenger cars and light-duty (3856 kg,
8500 lb or less gross vehicle weight) trucks
equipped with a “low-friction” engine.
Procedure fixture
A 1993 4.6-liter Ford “modular” V-8 gasoline engine
equipped with an external oil heating/cooling system
and a “flying flush” system for changing oils without
an engine shutdown is used for this procedure.
Procedure parameters
Fuel consumption is measured at each of five
speed/load/temperature procedure conditions for an
SAE 5W-30 baseline oil (BC). The candidate oil is
then introduced and aged for 16 hours at Aging
Phase I conditions and fuel consumption is then
measured for each of the five procedure conditions.
The candidate oil remains in the engine and is aged
for 80 hours at Aging Phase II conditions. Then fuel
consumption is measured for each of the five
procedure conditions, followed by a repeat of the
baseline (BC) oil at the five procedure conditions.
The BC oil is a a PAO synthetic oil from what I have read here in the distant past.
