I am fed up with alkalines, I use AA, AAA in most things, and they always leak, good brand Duracell.
I'm seeing good things on forums about Panasonic Eneloop batteries.
I really like the recharge ratings, and I do wonder if these batteries hold up the hype.
I use AA's in clocks, and AAA's in headlamps and flashlights.
I am also a little confused on Ni-MH battery chargers, what is the preferred charger between a timed charge vs a charger that uses "negative delta-voltage detection." Pro/Cons?
