This morning I checked out a 1999 VW Jetta with a 2.0L engine that a friend of mine was considering buying.
The car passed Safety Certification and Emissions Testing yesterday. I am in Toronto, Canada.
When I plugged my scanner in, three misfire codes came up, Engine Misfire/ Cylinder 1 misfire/ Cylinder 3 misfire. I think the numbers were P0300/P0301/P0303.
I am using a Innova 3130 scanner. My question is -- can cars pass emissions tests with fault codes present?
I also checked cranking compression in cyl 1 and it was 205psi.A relative compression test with a amp clamp around the starter cable showed equal compression on all cylinders.
What might be likely causes of this misfire? Should I recommend against the purchase because of this misfire?
The two plugs I removed(#1 and 4) looked normal.
