I have done a little research on this, and very little has been done in the way of electronic valves for modern day engines. I have seen some info where they still use a cam, but in my opinion there is no reason to use a cam when a board the size of a watch could be used instead, and eliminate the cam, and all the components at once.. Those that know about electronic valves I would like to ask is the reason why they don't go in this direction due to the electronic solenoid/valve not being a reliable part the reason ?
I work with electronic valves every day, and they are small, light, and the part driven is also light. I have worked on electronic valves that controlled air ( and very fast off on on this with lots of pressure) and a small object such as a rod, rod attached to a disc etc. They are very easy to program changes to opening/closing times as well, these I worked on are DC, and a board that drives the valves.. board being slang the first older boards were units that were large, and pretty much toast when anything went wrong, if a ceramic liner inside the solenoid wore away causing it to short out. then the next step was a board twice the size of your hand, now a chip on an I/O board pretty much takes care of everything.
I don't understand why this technology does not trickle over to the automotive side.
