Electricity Usage for Engine Heaters
Shel_B
Site Donor 2022
When I was traveling through Alaska and Canada I saw instances where cars would be hooked up to electric heaters to keep the oil/water/block warm enough to allow easy starting in very cold weather. How much electricity do these heaters use? How does their use compare to charging an EV?
Suburban Washington DC
I put one of those in my 1972 Dart after coming home from an Alaska/Canada road trip back in the 80's. Not sure it did much good around here, but I thought the cord sticking out from the grille looked real cool. Got a lot of questions about it.
Winnipeg MB CA
300 to 500 W is typical for my vehicles' block heaters over the years, and my present incremental cost of electricity is about C$0.093/kW-h, so my cost of running a block heater is between C$0.03 and C$0.05/hour.
The rise in coolant temperature when heated by a block heater drops off with time - the gain is rapid at first, and drops off quickly, with 90% of the benefit occurring within 3 hours, and no additional benefit occurring after 4 hours.
Assuming one wants to run the block heater for maximum temperature increase, 4 hours will cost between C$0.012 and C$0.020.
It's false economy to not use a block heater in a cold climate; the few cents of electricity used is offset many times by reduced battery, starter, and engine wear, and greatly reduced fuel consumption.
There's also the comfort of having cabin heat much sooner, when the coolant starts at +20°C rather than -30°C.
To answer your question directly, the amount of energy used by a block heater would be miniscule compared to the energy used to recharge an electric car.
North Carolina
And the reason you need a 1000W engine heater in North Carolina is???
Do you drive your car exclusively in your state of residence?
The cord sticking out from the grille looks real cool. :ROFLMAO:
Not here. Hack installs aren't really my style.
Highboy
Site Donor 2022
Saint John,IN
I put a cartridge heating element in my Scion Tc. Toyota has a hole cast in the head/block to put it into. About 2.5- 3 hours gets me to about 70 degrees according to my UltraGauge even when it gets down to single digits.
New England
I have had no issues starting a vehicle down to -23F since 1988.
The reality is at those temps the issues I had an engine block would not help much as I stalled engine letting clutch out on a manual transmission in neutral.
Shel_B
Site Donor 2022
My F150's block heater is 400 watts and I have a 150 watt oil pan heater as well.
Do you run them together or separately, and what determines your choices?
