- Joined
- Jul 28, 2024
- Messages
- 1,492
if you run heavier enough conductors you can check with an electrical supply house if they have 100% continuous load rated circuit breakers designed for your panel.
While thats not a bad idea. The breaker is either on or tripped. This won't fix his charging cable getting too hot issue.if you run heavier enough conductors you can check with an electrical supply house if they have 100% continuous load rated circuit breakers designed for your panel.
The attitude is interesting. I get saving $, but. HmmYou assume that it is not overheating, when the evidence suggests that it is, in fact, overheating.
I would not rule out improper wiring. I would not rule out cheap parts, developing corrosion, and/or pitting,
that's correct I would rule out a bad/weak/defective charging cable.While thats not a bad idea. The breaker is either on or tripped. This won't fix his charging cable getting too hot issue.
Wow ! Have to wonder if you'll acknowledge that one of us that "doesn't get it" was right in the end.Thanks. Someone who gets it.
lol. That’s why we were given a mind so we can all be legends.Wow ! Have to wonder if you'll acknowledge that one of us that "doesn't get it" was right in the end.
Installed the new outlet and plugged in the charger. The battery was pretty full but it still showed a 1.5 hour charge time. Checked it out at the 1 hour mark and the plug was cool to the touch. So I guess that the outlet had gone bad.
Don
Yeah not really sure which one I had. I just took it out of the garbage to investigate and cannot find any identifying numbers. I do see it is spec grade so there is that. I am not sure that the one I ended up getting is actually better than the old one or not. But it is working correctly. I would really like to find one that is leaps and bounds better than what I have now though. I really don't want to have to replace the outlet every 5 or 6 months.Which Leviton receptacle did you originally use? I see 5821 at Home Depot which is supposedly commercial grade:
https://www.homedepot.com/p/Leviton...hite-1-Pack-05821-0WS-R52-05821-0WS/100356999
Interesting that it couldn't handle the continuous load. Good to know that the industrial grade 5461 holds up
https://www.homedepot.com/p/Leviton...eptacle-White-1-Pack-05461-W-5461-W/301207446
