I've noticed that once turned off, my engine temp (at the gauge) creeps up 20* during heat soak. I've never seen that much creep. I don't know about the jeeps, but I do know that many e-fan circuits are NOT ignition-switched and can run when car is off (ever see those warning stickers under the hood?). If that's the case, heat soak could raise the coolant temp, run the fan for 1-2 minutes, then shut down.
M
