It does seem there were some 2022's that used the old parts. As you might expect, Ford won't say and the information is inferred.
As always, reset the TCM, make sure you have fresh fluid and perform a drive cycle, should help. It is good to know that the 10R-80 is a heavy duty transmission with 6 clutches and 4 planetary gearsets, designed for high torque applications. Shifting is not expected to be ultra smooth like might be experienced in a ZF-8HP, due to the way it is configured to achieve 10 forward speeds.
I understand you’re trying to be diplomatic
List of the latest 6 failures known for now:
If you learn better by visual and audio I have provided below links to such videos.
If you learn better by reading I Also below have provided my somewhat condensed version of the videos and information I found.
LIST OF LINKS:
When it comes to Ford 10R80 failure points, a Instructor at SIU, and a couple others I found, describes weak points for your Ford 10R80 and GM 10L80 10-speed to behave erratically and eventually fail.
CDF Drum. In earlier versions of the 10R80, a poorly designed bushing inside the CDF Drum slides out of position, allowing a Teflon seal to fail, resulting in pressure loss.
- Outer Shell Problems. The 10R80’s outer shells are made of aluminum, which is softer than the steel used to make the transmission’s various clutches. Sometimes these clutches stick into the divots in the outer shell, causing weird shifts.
- Valve Body. Valve bodies are what control the physical shifting in an automatic transmission. But if too much fine metallic contamination collects in the valve body, they behave out of spec. Which is why Dunsford always recommends replacing valve bodies anytime a 10R transmission is rebuilt.
- (In the 10R80, planetary gear sets and the one-way clutch are vital for maintaining smooth gear shifts and appropriate gear ratios. Deficiencies in these components can lead to improper shifting or transmission failures. A faulty one-way clutch might cause skipping of gears or failure to hold power in specific gears.
Friction clutches also play a role in this system, and their wear can exacerbate these issues. Keeping an eye on gear shifting behavior can alert you to early signs of these problems. Repairing or replacing these components early can prevent costly overhauls. From:
https://cartipsdaily.com/10r80-transmission-problems )
Another gentleman and his background:
https://www.f150forum.com/f118/unique-10r80-problem-solutions-experiences-options-566008/
I’ve done a lot of reading! And watching of videos about the many problems, poorly built and design issues with the 10R80/10L80 transmission. There are multiple multiple threads and forums about how horrible these transmissions are.
Again, why did I win my lawsuit against Ford if it is such a great transmission.
Why do people have to wait months and years to get their transmission replaced? I recently communicated with a police officer (private truck) that even paif for all the extended warranties on his truck and it took them five years to finally agree to replace his transmission.
I can supply other videos and information about the horrible 10 speed transmission at Ford and Chevy made together.
