17 Forester. I posted about this last winter and my alignment is supposedly in spec. Someone said it's a Subaru thing. Tire shop thought it was interesting, too, but said stuff looked fine. I'm going to take to the dealer this summer. Basically the inner and outer edges of all 4 tires have a pinkie width area where the siping is like melted together or gone basically. So it's smooth. You can see faintly where the siping was. Tire shop mentioned low air pressure and I side nope, I check at least twice per month and run them at 35 which is more than the door placard. They recommended the dealer and said maybe Subaru has more knowledge but it's not common from what they see and suspension and alignment seemed ok to them. Any ideas? Don't have the car near me now but I'll try to post pics again later.
Edit: the OE Yokohamas went 75k miles with 4/32nds left across the entire tire but the same oddity on the outer edges. The tread isn't any less, so to speak, but it's just smooth and the siping is destroyed or smoothed out like a pinkie width wide about a pinkie width from the inner and outer edges.
