Edge EP 0w20 doesn't meet dexos 1
NJ
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/6BD5DE4872AB5E8B80257E7D006877B9/$File/BPXE-9C77UN.pdf
Just noticed the Castrol EDGE Extended Performance 0w20 does not meet dexos 1 and it could be due to the high volatility of this oil. It was tested at 13.2% by PQIA. Mobil 1 0w20 is 10%, and so is Pennzoil Platinum 0w20.
The 5w20 Castrol EDGE Extended Performance is the more robust 20 grade and what I would go with among the two. Meets dexos 1 and GM 4718M (obsolete). (
A good find, I would hesitate to question why its not dexos 1 since for every quart of dexos 1 oil sold you have to pay a fee to GM.
I thought it was 12%. Castrol EDGE Extended Performance 0w20 is a great oil like the rest of the line. I was just pointing out folks may want to opt for the 5w20. A bit more robust.
MY stash is Dexos 1 as well as HTO-06 which is Hondas turbo and it will be interesting what Honda recommends for their "optional" 1.5 TURBO, yes and their SI might be a 2.0 l turbo and Rtype 3.0 and on and on and go forth...
NOACK standards are expressed to two significant figures, so 13.5% would be considered on-spec. Castrol EDGE Extended Performance 0w20 is dexos licensed
Originally Posted By: Ram01
Wow Castrol is underperforming with the edge line
How do you figure? 13.2% for a 0w-20 is not a terrible number at all. There are certainly full synthetic oils with a higher NOACK in their 0w-20 range. If you look at the other numbers of the VOA on PQIA you'll see it is quite robust in other areas including additives and the TBN.
How has castrol been with keeping engines clean without varnish like PP M1
