EcoGard X1A Cut Open 6000Km glue failure
Run
Canada
This was in service over the winter months and seen a bunch of short trips. Vehicle it came off from was a 2002 grand caravan. This is the first filter I cut open and discovered problems that would allow unfiltered oil to pass through. Once I cut the can open I reach in to pull the media out and off comes the endcaps. The large crack in the glue came from the base end of the canister. I always cut mine from the dome. So it was not damaged by me during the cut. I will not use these filters again.
Originally Posted By: PimTac
It fractured right in line with the pleat clamp. Was the filter installed way to tight?
I remember installing it just right. I was able to remove it with my bare hands.
The whole potting media in glue to make the seal is a pretty primitive process. I don't blame you for not wanting to use them again. I have the same feelings about Fram TG, EG, Baldwin, and a couple others. Based on this I wouldn't use the Eco's either.
What is that, missing glue on one picture? Even worse than oil bypassing is loose glue IMO.
