I have a John Deere X380. I was able to change out 400 cc of old hydrostatic oil, using a Mityvac.
On my transmission, there's a vent plug at the top, left, rear of the tranny. I pulled off the cover, then the plug, and was able to fit the small hose from the Mityvac, down the opening. I pulled out 400 cc of old oil, then used the Mityvac to force back in the same amount of new 20w-50 Pennzoil.
I did not need to bleed the hydro section of the pump, the tranny worked normal upon startup.
For those of us who don't have a drain plug, this method might work.
