What vehicles are a piece of cake to change oil and filter ?
My '00 MB E430 is so easy to change oil + filter without getting under the car, with the help of an oil extractor I could suck out used oil as much as dropping drain bolt. Cartridge filter is on top of engine near the front bumper so that it is easy to change without extend the arm.
Cartridge filter on the car is so easy to remove, I remove the filter to take a peak every few thousand miles to be sure it still in good shape and no crud nor sludge on the filter.
Oil + filter can be changed without a drop of oil spilled on the car or garage floor. If most cars are so easy to do oil change, most lube places would be closed in no times.
